Message |
Hi everyone, I recently replaced my EFI harness in my 91 TTZ. I followed this writeup, but when I broke open the pouch next to the ECU, I could not find the bundle of injector wires on pin 58. There was only a single 12 gauge wire joined to a 18 - 20 gauge wire that went to pin 58. HOWEVER, I found the injector wire bundle on the other side of the Harness! It looks exactly like the one near the ECU side. To be absolutely sure that was it, I measured Volts when the car was off (you should get +12V) then I disconnected the #1 injector connector and tested continuity between the connector and the bundle. I did this to eliminate any doubt. See pics below.
I ended up using a relay, but I'm sure you can route a wire back through the firewall to pin 45. -mike
